They recommended an oil/filter change and transmission oil/filter change.
I took it to a lube joint who changed the oil/filter and flushed the engine. They told me they could not change the transmission fluid as it sat behind the muffler. Is this the case? Also, do I NEED to change the transmission fluid? How can I tell if it needs changing and do I need to have it dealer serviced or will local mechanic do?
thanks!
Monday, July 14th, 2008 AT 1:01 PM
