1998 Ford Explorer Won't Shift Into 4th
BMINN5000
1998 FORD EXPLORER XLT
2 WHEEL DRIVE
4 SPEED AUTOMATIC WITH ELECTRONIC OD
4 LITER V6 106714 MILES
NO LEAKS, NO NOISES, RUNS GREAT, IT RUNS OUT GREAT JUST WONT GO INTO 4TH GEAR ANYMORE
4TH GEAR OD IS SELECTED BY PUSHING SWITCH AT END OF GEARSHIFT LEVER...TRANSMISSION CONTROL INDICATOR LIGHT ON INSTRUMENT CLUSTER FLASHES YELLOW ALL THE TIME...IT WILL NEVER GO INTO 4TH
Jun 23, 2007 at 5:29 AM
2CARPRO JACK
  • 11,533 POSTS
HAve the PCM scanned. Might have a code that will point you in the right direction. I have replaced a few of the switches/shift arm assemblies for this very problem. But the switch should be tested for proper operation first
Jun 24, 2007 at 2:09 AM
Suggested Repair
Scan the PCM for diagnostic codes, then test the overdrive switch on the gearshift lever for proper operation. If the switch fails, replace the switch or shift arm assembly.
Conversation Summary
The owner of a 1998 Ford Explorer says it runs well with no leaks or noises but will not shift into fourth/overdrive, and the transmission control indicator light flashes yellow constantly. The expert advises scanning the PCM for codes and testing the gearshift overdrive switch before replacing the switch or shift arm assembly.
