1996 Ford Explorer Clutch Pedal Soft
SHOOK92
  • 6 POSTS
I have a 1996 ford explorer 4x4 , there is no clutch pedal unless i pump it 10 or 12 tiimes then it stiffens up long enough to put it in gear without grinding , clutch fluid is full. no leak's
May 8, 2007 at 5:50 AM
MERLIN2021
  • 17,250 POSTS
It's either the master or slave cylinder has an internal leak...fluid passing by the seal...
May 8, 2007 at 6:09 AM
SHOOK92
  • 6 POSTS
fluid level hasn't gone down any ? and i dont see any leak's
May 13, 2007 at 3:33 PM
MERLIN2021
  • 17,250 POSTS
Have someone push the clutch while you bleed it...see if there is pressure, or the master is weak...
May 14, 2007 at 12:34 AM
Suggested Repair
Suspect an internal leak in the clutch master or slave cylinder. Have a helper press the clutch while bleeding it to check for pressure and whether the master cylinder is weak.
Conversation Summary
The owner of a 1996 Ford Explorer 4x4 reports no clutch pedal unless it is pumped many times, after which it briefly stiffens enough to shift without grinding. The fluid is full and no external leaks are visible. The expert says fluid may be bypassing an internal seal in the master or slave cylinder and recommends bleeding the clutch with a helper to check pressure and master-cylinder strength.
