1999 Ford Explorer Gas Pedal Stuck
LADYJ
I have a 1999 ford explorer xtl awd with 210,000 this morning on my way to work as I turned out on to our 4 lane my GAS PEDAL locked up...I got on the shoulder and had to slam on the pedal to dislodge it... what do I need to look for so this doesn't happen again thank you
Aug 20, 2006 at 10:25 AM
MIKEYBDMAN
  • 623 POSTS
[quote:c6d043b3e5="ladyj"]I have a 1999 ford explorer xtl awd with 210,000 this morning on my way to work as I turned out on to our 4 lane my GAS PEDAL locked up...I got on the shoulder and had to slam on the pedal to dislodge it... what do I need to look for so this doesn't happen again thank you[/quote:c6d043b3e5]
Look for a kinked, frayed or binding throttle cable. It could also be a worn or damaged throttle bottle. Before taking it to a mechanic, just look under the dash at the cable and mechanism. then look under the hood where the dable attaches to the throttle body. Make sure there are no foreign objects caught inthe linkage.
Aug 20, 2006 at 11:00 AM
SERVICE WRITER
  • 9,123 POSTS
Most likely the flap in the Thottle body is gummed up with carbon. IT can be cleaned out.
Sep 4, 2006 at 12:47 PM
Suggested Repair
Inspect the throttle cable for kinks, fraying, or binding, and check the linkage under the dash and at the throttle body for debris. Clean carbon buildup from the throttle body plate; replace the cable or throttle body if worn or damaged.
Conversation Summary
The owner of a 1999 Ford Explorer said the gas pedal locked up and had to be slammed to free it. Experts advised checking the throttle cable and linkage for binding or foreign objects and cleaning carbon from the throttle body.
