When i press on the gas pedal there is a weird noise, but it stops once I go over forty mph
197,000 MILES • 4.6L • V8 • 4WD
STINA MARIE
My passenger side wheel has been making a weird noise. It is only when I push on the gas and once I got past 40 mph it stops.
Oct 12, 2016 at 2:08 AM
HMAC300
  • 48,601 POSTS
drive in a left hand circle and if noise increases it may be a wheel bearing. then drive in a right hand circle if noise reduces that will verify it. it could also be an axle shaft so it may do the same.
Oct 12, 2016 at 2:23 AM
