1997 Ford Explorer Brake Pedal to Floor
TJOHNSON1201
  • 7 POSTS
I have a 1997 ford explorer 4wd I have replced the pads callipers and rotors on the front and a new master cylinder. Still no pedal goes straight to the floor.
Apr 26, 2007 at 9:24 AM
TJOHNSON1201
  • 7 POSTS
Yes both sides were full and no brake light. One of the rotors had some weare on them. So i decided to replace calipers and rotors both.
Apr 27, 2007 at 1:40 AM
TJOHNSON1201
  • 7 POSTS
When pushing down on brake to almost complete stop you could fell it jerk to the right and the pedal push back against your foot.
Apr 27, 2007 at 6:06 AM
TJOHNSON1201
  • 7 POSTS
No after replacing the callipers then i bleed it. The pedal was still very low to the floor. I then replaced the master cylinder and i did bench bleed it. So it is still going to the floor. After all this now.No brake light has ever came on or the abs light either.
Apr 27, 2007 at 12:06 PM
TJOHNSON1201
  • 7 POSTS
I have had the truck for 3 years and 60,000 miles no other problems have ever come up on it. When i bought it put new pads on front and rear with new rotors in rear. Nothing else besides that.The pedal going to the floor happened after i replaced the front callipers. That was the reason for replacing master cylinder.
Apr 27, 2007 at 2:42 PM
MERLIN2021
  • 17,250 POSTS
Try gravity bleeding with both front caliper bleeders open, keep the master cyl full and let em drip for a while. The other aspect to your problem, did you start this because the pedal was low? If so check your rear brakes! They control pedal height, if they are not adjusted properly, pedal will be low!
Apr 27, 2007 at 8:29 PM
TJOHNSON1201
  • 7 POSTS
no after replacing brakes had little peddal could pump them up. So then replaced master. After this and bench bleeding the master and gravity blkeeding and a pump to bleed with there is no pedal at all.
Apr 28, 2007 at 12:13 AM
MERLIN2021
  • 17,250 POSTS
How was the pedal height before the brake job? If it was ok...look for the combination valve, have someone hold the needle at the end in while you bleed the front brakes, If that dosen't work get a power bleeder and bleed all four wheels in the proper sequence.
Apr 28, 2007 at 2:41 PM
TJOHNSON1201
  • 7 POSTS
Ok dumb question time. What is the combination valve.
Apr 29, 2007 at 3:15 AM
Suggested Repair
Gravity-bleed the front calipers while keeping the master cylinder full, and check rear brake adjustment because it controls pedal height. Hold the combination valve metering pin in while bleeding the fronts. If the pedal is still low, use a power bleeder and bleed all four wheels in the proper sequence.
Conversation Summary
A 1997 Ford Explorer 4WD has a brake pedal that goes to the floor after the front pads, calipers, and rotors and the master cylinder were replaced. The master was bench-bled and the system was bled, but there is still no pedal; no brake or ABS light has come on. The pedal became low after the caliper replacement and could be pumped up, then disappeared after the master cylinder was replaced. The expert advised gravity-bleeding the front calipers, checking rear brake adjustment, holding the combination valve pin in while bleeding, and using a power bleeder on all four wheels if needed.
