1999 Ford Explorer ABS Light On
JWHIT
  • 6 POSTS
I have a 1999 Ford Explorer with the ABS Light on. Is there any way to pull codes other then with a NGST Star tester. I know years past you could jump 2 pins and count pulses. Is that not possible on the newer models.
Jun 9, 2006 at 2:07 PM
TAURUSWHEEL
  • 718 POSTS
Get yourself one of the obdII scan tools, various prices depending on their complexity,, I think they can be had for less then a hundred bucks, that price can't do the data stream info, but they'll certainly point you in the right direction with your abs issue,, some of the older fords, up to 95, the abs could be read using the eec4 scan tools available, connector was the same for both.
Jun 9, 2006 at 5:03 PM
Suggested Repair
Use an inexpensive OBD-II scan tool to read the ABS codes. The pin-jump method and EEC-IV tools applied to older Fords through about 1995, not this 1999 Explorer.
Conversation Summary
The owner of a 1999 Ford Explorer has the ABS light on and asks whether codes can be retrieved without a Ford Star tester, such as by jumping pins. The expert recommends an OBD-II scan tool to point toward the ABS fault and notes that the older scan method was for Fords up to about 1995.
