i thank you very much.
1997 Ford Explorer ABS Light On
The abs system is separate from the hydrolic brake system. I expect that you have a wheel speed sensor going bad. May be part of the wheel bearing and hub assy. Take a look for the wiring harnesses going to the sensors and check for damage or bad connections first.
You will need to pull codes from the body control module to narrow it down as you know.
Good luck.
Good luck.[/quote:21355061a5]
That's a rarity! At least from what I have seen. But good to post none the less!
Could this be a precursor to a bigger problem with my electrical system? What voltage should there be at the fuse block?
Could this be a precursor to a bigger problem with my electrical system? What voltage should there be at the fuse block?[/quote:88b783ee9d]
I really wish I could discuss electical testing intelligently and such, but I am still learning it. Therefore I can't answer the question of voltage. I just haven't seen many relays go bad versus sensors. It is certainly possible and on a larger may be more common.
Tauruswheel suggested that earlier and is good advice.
For the po174, Chris wrote a good post for that:
https://www.2carpros.com/forum/p0171p0174-ford-40l-common-causes-testing-and-fixes-vt27348.html
It also has some replacement procedures for the ABS sensors and control units.
I don't see that info in the "Haynes" manual.
Im not very familiar with abs systems on FORD cars, so this may not be true of fords.
Suggested Repair
Scan the ABS system through the body control module; a basic OBD-II scan may not show ABS codes, so use a capable scanner such as a Mastertech or Rotunda NGS. Inspect wheel-speed sensor wiring and connectors first. A failing wheel-speed sensor or hub assembly is the most likely cause; a bad ABS relay is less common but inexpensive to check.
Conversation Summary
The owner of a 1997 Ford Explorer Sport Trac with about 188,000 miles reported an ABS light with new brakes and normal stopping. Experts said the ABS system is separate from the hydraulic brakes and recommended scanning the body control module, checking wheel-speed sensor wiring, and considering a bad sensor or hub. An OBD-II scanner was suggested, and a 1993 Explorer case of a cheap failed ABS relay was mentioned as uncommon. The owner later retrieved P0174, which is not an ABS code, and was told ABS codes are stored in the body control module.
