Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Brakes
ABS
Codes
2000 Ford Explorer ABS problem
2000 FORD EXPLORER
206,288 MILES • 6 CYL • 4WD • AUTOMATIC
MARIOSL
MEMBER
1 POST
hi i have a ford explorer 4x4 2000 the abs comes on just before i come to a complete stop but there is no ABS code
Nov 25, 2009 at 6:12 AM
RICKMAR
Experienced Mechanic
I would check you anti-lock sensors. I would say having 206288 miles they just might need to be replaced Here is a sketch showing there location.
(1) Hold down bolt --- re-torque to (62 - 80 Lb/in) (2) Anti-lock brake sensor. Good Luck; Rick
Nov 25, 2009 at 8:29 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
