2001 Ford Explorer Low Speed Brake Slip
DARENG
  • 5 POSTS
Hi all. I need a little help diagnosing a brake problem. My SUV truck is 2001 Ford Explorer Sport - SOHC 2 wheel drive. I recently replaced the rotors, brake pads and bearings on all 4 wheels.
Now my truck brakes on a dime especially when I brake hard. It also brakes smoothly with no issues when braking hard. However, I noticed that when braking at low speeds, my brakes appear to momentarily dissenguage or slip for a moment. This only happens when driving at low speeds. This does not happen every time but often enough to notice there is an issue.
I double checked for the proper torque on the caliper bolts. I didn't remove the brake line hoses from the caliper when I did the brake job. I don't think I did anything else to break the system so I don't see how I could have gotten air in the system.
So I am a little stumped what could be causing the issue. Could air in the line be causing this issue? I was experiencing so much pulsating in the brakes before I replaced the rotors that I guess I might not have noticed the truck doing this before. My only other thought was a sticky caliper. However, I doubt that because the calipers compressed just fine when I did the brake job.
I'm stumped.
Aug 16, 2006 at 4:01 AM
DARENG
  • 5 POSTS
OK, update. Just driving it a bit, I noticed that number 1, the brakes don't do it all the time. Two, that when it does happen, if feels like the brakes are engauged and then they slip just before I come to a stop.
I also noticed now that when I go over 55 miles per hour, I sense a slight wobble. I wasn't not getting that prior to changing the pads and rotors.
Does this sound more like a stuck caliper?
Aug 28, 2006 at 6:07 PM
DARENG
  • 5 POSTS
Anyone?
Sep 6, 2006 at 9:23 AM
NOS
  • 320 POSTS
it sounds like you may have a brake line problem. Q: were the pads wore down worse on one wheel more that the other? what i would do is start at the front , jack it up. have a friend help you. have him step lightly on the brake and try to turn the wheel keep doing it till it stops with lots of resistance have them hold the peddle there and go to other side and see if wheel turns. sometime when the factory crimps the holding bracket to the hose they get carried away and over a period of time the hose collaps inside and lets fluid pass through but makes it return slowly to the master cyclinder the next time you use the brake the fluid may not folw to the caliper soon enough and cause the slow stop. not always but most of the time it is the right one that hangs up. hope this helps. (NOS) 8)
Sep 6, 2006 at 11:08 AM
DARENG
  • 5 POSTS
[quote:748188f9d3="NOS"]it sounds like you may have a brake line problem. Q: were the pads wore down worse on one wheel more that the other? what i would do is start at the front , jack it up. have a friend help you. have him step lightly on the brake and try to turn the wheel keep doing it till it stops with lots of resistance have them hold the peddle there and go to other side and see if wheel turns. sometime when the factory crimps the holding bracket to the hose they get carried away and over a period of time the hose collaps inside and lets fluid pass through but makes it return slowly to the master cyclinder the next time you use the brake the fluid may not folw to the caliper soon enough and cause the slow stop. not always but most of the time it is the right one that hangs up. hope this helps. (NOS) 8)[/quote:748188f9d3]
All the pads were pretty even but the drivers side back one. That pad had more wear then the others.
Sep 6, 2006 at 11:35 AM
NOS
  • 320 POSTS
did you make sure that the slides that the bolts went through were good and free and moved easy? i don't think you have and air problem :lol:
Sep 6, 2006 at 11:44 AM
DARENG
  • 5 POSTS
[quote:bd3ecda3a0="NOS"]did you make sure that the slides that the bolts went through were good and free and moved easy? i don't think you have and air problem :lol:[/quote:bd3ecda3a0]
Not sure what you mean. The only bolts I had to remove were the caliper bolts. I double checked with a torque wrench to make sure they were right. They went in nice and easy without any obstruction.
Sep 6, 2006 at 4:37 PM
NOS
  • 320 POSTS
what i mean is on the caliper there are two cyclinder looking things that the bolts go through these have to move back forth so the caliper has something to move back and forth on that is where it gets its clamping power from once you bolt them back on they got to be able to move so whem you step on the pedle the caliper moves on these sleves so the outer shoes can clamp too it is like takeing two of your fingers on one had and squeeseing the together well the caliper works in same way if it can you get poor breaking cause it can't clamp. hope this explains a little better.(NOS)
Sep 7, 2006 at 12:04 PM
Suggested Repair
Inspect the flexible brake hoses for internal collapse that can delay fluid return and the next application, and verify the caliper slide pins or sleeves move freely so both pads clamp. Compare front wheel drag side to side with light pedal pressure. Air in the lines is unlikely.
Conversation Summary
After replacing rotors, pads, and bearings on a 2001 Ford Explorer Sport, hard braking is strong and smooth, but the brakes often slip just before a low-speed stop. A slight wobble above 55 mph also appeared after the job. Pad wear was mostly even except for more wear on the driver-side rear. The expert does not suspect air in the system and recommends checking for a collapsed brake hose and free-moving caliper slides.
