1996 ford explorer clutch problem
1996 FORD EXPLORER
SHOOK92
  • 6 POSTS
I have a 1996 ford explorer 4x4 , there is no clutch pedal unless i pump it 10 or 12 tiimes then it stiffens up long enough to put it in gear without grinding , clutch fluid is full. no leak's
May 8, 2007 at 5:50 AM
MERLIN2021
  • 17,250 POSTS
It's either the master or slave cylinder has an internal leak...fluid passing by the seal...
May 8, 2007 at 6:09 AM
SHOOK92
  • 6 POSTS
fluid level hasn't gone down any ? and i dont see any leak's
May 13, 2007 at 3:33 PM
MERLIN2021
  • 17,250 POSTS
Have someone push the clutch while you bleed it...see if there is pressure, or the master is weak...
May 14, 2007 at 12:34 AM
