cant find a dip stick
NAY9677
ok i have a 93 ford explorer 90143 mls i think its a 2.2 lt engine and it is a manuel trans 5 speed. does it have a dipstick for transmission fuild and where would it be located. also while driving the car makes a kind of grinding noise or if it over reeved, not like if you didnt get the gears in right tho, when ever i push in the clutch it stops. do i need a new cluch. :D
Nov 28, 2007 at 9:01 AM
BMRFIXIT
  • 19,053 POSTS
[quote:7049c35bcf="nay9677"]ok i have a 93 ford explorer 90143 mls i think its a 2.2 lt engine and it is a manuel trans 5 speed. does it have a dipstick for transmission fuild and where would it be located. also while driving the car makes a kind of grinding noise or if it over reeved, not like if you didnt get the gears in right tho, when ever i push in the clutch it stops. do i need a new cluch. :D[/quote:7049c35bcf]
No dipstick for manual tranny and it sound that your do for a clutch and bearing
Good luck
Nov 28, 2007 at 9:17 AM
