Possible Transmission problem
PRETTIE_GIRL_2
I have a 2002 Ford Explorer XLT, V6 4.0, 4WD, with approximately 94000 miles. I'm afraid I have a transmission that may be going astray! I'm experiencing not hearing the vehicle shift when it's traveling 30-40 mph, then it shifts normally, at takeoff there's a slight hesitation but nothing major and not at every takeoff. I hear no strange noises other than my differential that I have recently been told will need to be replaced. Do the two have anything to do with one another? I attempted to check the transmission fluid but found no dipstick and was told it needed to be put on a lift to be checked! how convenient. Do you have any advice to put my worries at ease? I have read through the questions and notice in most cases you've recommended a transmission fluid change I sure hope that's the case! Thanks in advance.
Nov 7, 2007 at 2:07 PM
MIKE H R
  • 3,094 POSTS
There should be a dipstick on the passengers side of the engine compartment back by the firewall. with it not shifting properly, the first thing I suggest after you find the dipstick pull it out and smell it, and look at the color. if it smells burnt then i suggest a fluid change as well as the filter changed. the same if it has a brownish color. sometimes the dipstick is hard to find but it should be there.
Nov 7, 2007 at 2:16 PM
