2000 Ford Expedition Rear Wiper Arm
WHYBRI
I drive a 2000 Ford Expedition Eddie Bauer 4x4 V8 4.6L with 49k miles The rear windshield arm/motor popped out of the hole on the rear door. I was just wondering how I can access that so I can remount it. I guess there are screws on the interior panel but how many and were are they? Thanks in advance for any help you can give me.
Brian whybri@comcast.net
Sep 8, 2007 at 3:35 PM
MERLIN2021
  • 17,250 POSTS
you must remove the platic panel, there are I think 4 screws holding the panel and also some plastic hold downs. once you get that off, the motor should be fairly straightforward! Have someone help with the plastic panel, it breaks easily at the top if your not careful!
Sep 9, 2007 at 12:09 AM
Suggested Repair
Remove the interior plastic panel, held by about four screws and plastic retainers. Have a helper support the panel because it breaks easily at the top. Once the panel is off, remount the rear wiper motor.
Conversation Summary
The owner of a 2000 Ford Expedition said the rear windshield wiper arm and motor popped out of the hole in the rear door and asked how to access it for remounting. The expert advised removing the plastic interior panel, held by about four screws and plastic retainers, with help so the top does not break, then remounting the motor.
