2003 Ford Expedition Door Ajar Light
PEACHEY
47,000 miles
The door open light is on all of the time. The rear tailgate is causing this even if it is closed. Now it sounds like the tailgate is continually trying to lock whenever the car is running.
Any ideas?
Jun 5, 2007 at 9:33 AM
TAURUSWHEEL
  • 718 POSTS
Usually the open light is caused by a sticking switch, which needs to be lubricated, if your door lock is locking and unlocking continously, most likely a wiring issue or a faulty lock solenoid
Jun 5, 2007 at 9:36 AM
Suggested Repair
Lubricate the sticking tailgate ajar switch. If the lock cycles continuously, inspect the tailgate lock wiring and lock solenoid.
Conversation Summary
The owner of a 2003 Ford Expedition reports that the door-open light stays on because of the rear tailgate even when it is closed, and the tailgate keeps trying to lock while the vehicle is running. The expert says a sticking switch often causes the light and should be lubricated, while continuous locking usually indicates a wiring problem or a faulty lock solenoid.
