2002 Ford Expedition Door Locks Clicking
KWARE1
  • 5 POSTS
I own a 2002 Ford Ex Eddie B V8. It has 82,000 miles. I have an after market remote start and recently added a built in GPS/ Stereo system. A few weeks after the GPS was installed, (could be coincidence) the auto door locks just started click on and off, as if someone was pressing the switch. This would happen when the car was started, then stop after about a minute or two. After about a week or so, the door locks, along with the auto lamps stopped working altogether. After checking fuses, I tried disconnecting the battery, and everything went to normal for a few weeks before the locks and autolamps started click on and off intermittently for a couple of minutes after starting. disconnecting the battery would temporarily solve the issue, but now it at a point where if the battery is disconnected, the locks will work. Once the car is turned off, they will not work again- along with the auto lamps.
May 26, 2007 at 1:30 AM
MERLIN2021
  • 17,250 POSTS
Have you tried pulling the fuse for the remote start?
They do seem to cause problems, most intallers don't solder the connections!
Mar 23, 2008 at 12:59 AM
KWARE1
  • 5 POSTS
Thanks for your input.
No I have not tried pulling the fuse.
Is that on the alarm brain itself, or just the remote start part?
Also, are you suggesting I eliminate the remote start, or is this just a trouble shooting step?
Mar 23, 2008 at 11:07 AM
MERLIN2021
  • 17,250 POSTS
It's a troubleshooting step, some know thier business better than others....ANY add on electronics can cause problems if the wrong circuit is tapped for power...
Mar 24, 2008 at 5:34 AM
Suggested Repair
As a troubleshooting step, pull the fuse for the aftermarket remote start and see if the door locks and autolamps return to normal. Check that the remote start and GPS/stereo were not tapped into the wrong power circuit; poor or unsoldered add-on connections can cause this behavior.
Conversation Summary
A 2002 Ford Expedition with an aftermarket remote start and a recently installed GPS/stereo developed intermittent door-lock clicking after startup, then lost door locks and autolamps. Disconnecting the battery temporarily restored function, but the problem returned. The expert advised pulling the remote-start fuse as a diagnostic step and noted that improperly tapped add-on electronics often cause these issues.
