1998 Ford Expedition Low Fuel Pressure Fix
What brand of pump did you use?
Was the pump replaced to fix an issue or was this done at an earlier date?
is this a 4x4?
Does it have air suspension?
The pump was replaced two days ago vehicle would not start
4X4 yes
air suspension no
My experience is anything electical from Autozone is junk. Based on the TSB, I'd put in the dealer pump. I am real leary of a lot of aftermarket pumps. We have had bad luck with a lot of brands. Chysler ones I always go dealer. Gm -ac delco, Ford I recommend dealer, and don't give a labor warranty if aftermarket is chosen.
I'd drop the tank if you have to and blow air through the line to make sure it isn't plugged and check for proper power flow to the connector. If good use the ford revised pump according to the tsb spec sheet.
PAul
Hey Charlie,
Looks like you've got the problem nailed! your referring to the inertia switch right? a quick to to verify would be to disconn the switch and jumper the connection and ...... viola .......good fuel pressure should return
Chris
My email address is rocker1950@comcast.net if you don't mine sending me your phone number I will call you.
My email address is rocker1950@comcast.net if you don't mine sending me your phone number I will call you.[/quote:7b2b6e8fdc]
Wow, its bein' real pain. Time for some more testing! Have you done voltage tests further down the line? I would go right to the fuel pump connector and test there. Don't forget test test for a good ground also!
Let me know how that goes! Will email ya my biz # if all else fails!
Chris
Ok, and you verified a good ground for the fuel pump assy?
Chris
Charlie,
Ummmmm yup, we need to verify that there is not only got voltage to the f/p but also a good ground! Do you know how to test for that?? am emailing you my biz #
Chris
Suggested Repair
Have the dealer cut and program a new ignition key. The owner confirmed a bad key was preventing the pump from running; after the new programmed key, the Expedition started and ran normally.
Conversation Summary
A 1998 Ford Expedition 5.4 with about 92,600 miles had almost no fuel delivery and would not start. The owner had already replaced the fuel pump and filter and checked the relay and fuse. Experts questioned the aftermarket pump, suggested checking the lines, power, ground, and the inertia fuel-pump shutoff switch. Voltage dropped across that switch, and a jumper restored voltage at the pump connector, but the installed pump still did not run. The owner later reported that a bad key was the cause; the dealer cut and programmed a new key and the vehicle ran fine.
