Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Expedition
Fuel System
Fuel Pump
Not Working
Fuel Pump Plug?
2003 FORD EXPEDITION
170,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
RAYBEATZ
MEMBER
7 volts at the fuel pump plug. Fuel pump will not come on.
Feb 20, 2016 at 4:54 AM
CARADIODOC
Experienced Mechanic
Are you measuring that voltage while cranking the engine?
Feb 20, 2016 at 5:47 AM
WRENCHTECH
Just to add to this, you probably want to measure that with the plug disconnected from the fuel pump to get an accurate reading.
Feb 20, 2016 at 7:40 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
