KBARTER
Ford Excursion 2004 V8 $47,000. In driving my truck today, my brakes all of a sudden went right to the floor. They worked but there was no resistance. Once I pumped them, they came back. In driving it more later on in the day, it happened again. I stopped at the local garage and had them check the brake fluid and it was fine. Any thoughts?
May 31, 2007 at 6:20 AM
FAULKYOUTO
maybe air pockets in the line
May 31, 2007 at 1:08 PM
RUDPRO
  • 224 POSTS
It's most likely the master brake cylinder. Look around the mounting flange area for signs of brake fluid. It could also have bad piston seals in which case you won't see any leaking.
May 31, 2007 at 5:53 PM
98RANGERXLT
  • 301 POSTS
Try bleeding the brakes.
Jun 2, 2007 at 5:18 AM
