2002 Ford Excursion Brake Warning Light
MPORTER13
I have a 2002 Ford Excursion 6.8 liter V-10 with 118000 miles. The brake warning lamp in the dash is iluminated. What should i look for?
Feb 12, 2007 at 11:53 AM
GARFIELD
  • 197 POSTS
The first thing I would check would be your brake master cylinder fluid level. If it is low add dot 3 brake fluid to fill it back up, and check it in a day to week later and see if the fluid level is the same if it is not then something is leaking and you need to find out where the brake fluid is going.
Feb 12, 2007 at 9:28 PM
Suggested Repair
Check the brake master cylinder fluid level. If it is low, add DOT 3 brake fluid and recheck in a day to a week. If the level drops, find and repair the brake fluid leak.
Conversation Summary
The owner of a 2002 Ford Excursion with a 6.8L V10 and 118,000 miles reports the dash brake warning lamp is illuminated. The expert advises checking the master cylinder fluid level, topping it up with DOT 3 brake fluid if low, and looking for a leak if the level falls again.
