2000 Ford Excursion Air Only From Defrost
PS parked autos are a haven for rodents and wiring and vaccum lines are food they make a mess of them Hint put put moth balls in pill bottles tih hole in the under the hood and it will dicourge them from making homes.
Can anyone help us?!
[quote:97068a3d30="devildog64"]I have a 2000 Ford Excursion with 38000 miles on it.. I park it every winter lifted off the ground and closed up.. When I took it out this year I the air only came out of the defrost vents and not the other. I looked for obstructions and have not been able to find anything. I opened the Glove box door and moved the valve back there and I can force it to go down to the floor but still does not come out of the AC vents and when I let go it goes back to the defrost. I am not sure if there is more then one valve or what the problem could be. Thanks..[/quote:97068a3d30]
I believe his suggestions may have helped me find what my problem was. Just in case some of you still have this problem, here is my solution (for a 95 Ford Ranger)...
Under the hood, on the engine's right side (passenger's side) there is a plastic sphere (plastic ball) located roughly behind the radiator underneath the radiator hose, which has two thin plastic hoses running to/from it. I'm pressuming this is some kind of vacuum ball. One of those thin hoses (about as thin as the spray nozzle of a WD-40 can) had broken off right on the rubber plug which connects to this "vacuum ball." I simply pulled the broken rubber plug connected to this ball, removed the broken piece wedged in this rubber plug using needle-nose pliers and some WD-40, and re-inserted the remaining loose hose into the rubber plug, making sure it was nice and tight, and plugged the rubber plug back onto the vacuum ball.
I started up the truck and VIOLA, all the vents work again!
So before you buy a new selector switch, or get hosed by a mechanic, make sure you check these two ridiculous lines first!
Good luck to all with your repairs, and thank you for your FAQ's and suggestions!
Suggested Repair
Inspect underhood vacuum supply lines and the vacuum reservoir canister for disconnected, broken, or rodent-damaged hoses, then reconnect or repair them. If vacuum reaches the cab, check the timed vacuum mode selector behind the climate controls and its colored lines; blend doors default to defrost when vacuum is lost.
Conversation Summary
A 2000 Ford Excursion only blew air from the defrost vents after winter storage. The owner could manually move a door behind the glove box toward the floor, but it returned to defrost and dash vents still did not work. An expert advised checking underhood vacuum lines for rodent damage and, if vacuum is present, the replaceable selector valve behind the controls that routes vacuum to the door actuators. A 1995 Ford Ranger owner with the same symptom found a thin hose disconnected at the vacuum canister, reconnected it, and restored all vent positions. Another Ranger owner later confirmed the same fix. Experts explained that the canister stores vacuum for the controls and that lost vacuum leaves the doors in the defrost position.
