2005 Ford Excursion Oil in Radiator
AZHARI MOBARAK
Hi please let me know how many hours of labour needed to replace engine oil cooler on a 2005 Excursion and flush the cooling system because oil got into the raidator, also what is the cause of this problem, this truck I only drove it for 2 month total milage is 3475, the truck was not in use for about a year. :cry:
May 5, 2007 at 9:19 PM
2CARPRO JACK
  • 11,533 POSTS
Depends on gas or diesel.... Labor times are gas-1.0 hour Diesel- 6.7 hrs for the oil cooler
flush is .7 hrs gas or diesel
Reason? hard to say, bad castings, under-engineered
May 6, 2007 at 1:35 AM
Suggested Repair
Confirm whether the Excursion is gas or diesel, then replace the engine oil cooler and flush the cooling system. Quoted labor is about 1.0 hour for a gas oil cooler or 6.7 hours for diesel, plus about 0.7 hour for the flush. The cause is uncertain and may involve a bad casting or an under-engineered cooler.
Conversation Summary
The owner of a low-mileage 2005 Ford Excursion that had sat unused for about a year asked how long it takes to replace the engine oil cooler and flush the cooling system after oil entered the radiator, and what caused it. The expert said labor depends on engine type: about 1.0 hour for a gas oil cooler or 6.7 hours for diesel, with a 0.7-hour flush for either. The cause is hard to determine and may be bad castings or under-engineering.
