1997 Ford Escort Idle Rocking
Suggested Repair
Perform wet and dry compression tests, focusing on cylinders 3 and 4, which did not change the idle when their plug wires were disconnected. Also inspect and replace the spark plug wires if needed. Exhaust liquid at high rpm was identified as condensation, not a confirmed fuel leak.
Conversation Summary
A 1997 Ford Escort 1.6L rocks at idle between about 800 and 1200 rpm, then smooths out around 1500 rpm. Cylinder 4's plug was gold/yellow with liquid on the threads, and disconnecting the wires for cylinders 3 and 4 did not change the idle, while cylinders 1 and 2 nearly stalled it. A borrowed coil helped only slightly. Experts said the exhaust liquid is condensation and advised a wet and dry compression test, along with checking ignition components and plug-wire contribution.
