1997 Ford Escort High Idle
LIHAASA
I have a Ford Escort 1997, manual, 122,000 miles. Lately the car has started idling at high revs. The problem is also observed whenever I press the clutch for shifting gears. What could be the reason for this?
May 31, 2007 at 12:54 AM
RUDPRO
  • 224 POSTS
It's probably the Idle Air Control Valve or Mass Air Flow Sensor. Is your check engine light on? If it is, get the computer scanned for trouble codes. you can get this done for free at an Autozone or some other auto parts store.
May 31, 2007 at 7:11 AM
Suggested Repair
Check whether the check engine light is on and have the computer scanned for trouble codes, which many auto parts stores do for free. Likely causes are a faulty idle air control valve or mass airflow sensor.
Conversation Summary
A 1997 Ford Escort with a manual transmission and 122,000 miles began idling at high revs, including when the clutch was pressed to shift. The expert suggested the idle air control valve or mass airflow sensor and recommended scanning for trouble codes if the check engine light is on.
