1998 Ford Escort Idle Surge
LILYBITT
Just purch. this vehicle. Serv. engine soon light is on solid, not flashing. Was told it was due to low quality fuel or needed oil chg. If read manual correctly, doesn't seem like something I need to rush on normally.
However, when I'm stopped, idling, hear a small click then what sounds like an engine surge. It's perfectly rythmic. Makes the sound for a few sec, then stop, then click then sound again.
I admit to knowing not much about cars or car care but do want to learn. Need to keep this vehicle on the road for at least another yr. with as little $ as possible.
Thanks!!
Dec 5, 2006 at 10:34 AM
WYNRYPEN
  • 52 POSTS
start with the basics, does it have fuel? is there a spark? start off by doing an compression test.
Dec 7, 2006 at 5:31 AM
BRUCE HUNT
  • 3,754 POSTS
Take some time to purge the cooling system of air. Then check for any vacuum leaks. Surging of an engine is caused because a sensor is unable to work or sense properly and thus is screws with the processing of the computer to regulate fuel flow.
Idle air control valve could be dirty. Intake could have a minor leak, vac leak, etc.
Dec 7, 2006 at 5:35 AM
LILYBITT
Has Fuel, don't know what a compression test is
Dec 7, 2006 at 5:36 AM
Suggested Repair
Bleed air from the cooling system, then check for vacuum and intake leaks. Inspect and clean the idle air control valve, since a dirty valve or a sensor that cannot read correctly can cause rhythmic idle surge.
Conversation Summary
The owner of a 1998 Ford Escort wagon with 92,000 miles reports a solid service engine soon light and a rhythmic click followed by an engine surge while stopped and idling. They were told the light might relate to poor fuel or an oil change and want an inexpensive way to keep the car running. A reply suggested checking fuel, spark, and compression. The expert advised purging air from the cooling system and checking for vacuum or intake leaks, noting that a dirty idle air control valve or a sensor that cannot sense properly can disrupt fuel control and cause surging. The owner confirmed the car has fuel but does not know how to perform a compression test.
