1998 Ford Escort P1131 Lean Code
JKAMYX
I got a trouble code P1131 which is a heated O2 Sensor 11 Indicates Lean. So what should I do about this? Do i need to replace the O2 Sensor? What does it mean that it indicates lean?
Sep 5, 2006 at 8:36 AM
SERVICE WRITER
  • 9,123 POSTS
It means that it is reading that the fuel/air mixure is lower on fuel and higher on air. I think it means either the sensor is bad or somthing is causing a lean mixture.
Sep 5, 2006 at 10:48 AM
SEMAJCANTLEY
  • 5 POSTS
I've got a 98 Escort and I once got the same code! I don't know much about cars (and it is certainly too late for you to read this!) but the problem was the ignition coil. Hopefully that helps something!
Sep 18, 2006 at 1:55 PM
NOS
  • 320 POSTS
look your engine over real close for a vaccum leak. start from you PCV valve and work you way back the the intake.(NOS) 8)
Sep 21, 2006 at 11:09 AM
Suggested Repair
Inspect the engine closely for vacuum leaks, starting at the PCV valve and working back to the intake. A P1131 lean reading can mean a faulty upstream heated O2 sensor or a real lean mixture, so do not replace the sensor until vacuum leaks and other lean causes are checked.
Conversation Summary
The owner of a 1998 Ford Escort has code P1131, heated O2 sensor 1 indicating lean, and asks whether the sensor should be replaced and what lean means. An expert explains that the mixture is low on fuel and high on air, which could be a bad sensor or something causing a lean condition. Another expert recommends a close vacuum-leak inspection from the PCV valve back to the intake. A later owner reported the same code on a 1998 Escort was caused by a bad ignition coil.
