2001 Ford Escort TCC Code Burned Fluid Fix
KEVWISE1
  • 6 POSTS
I have a 2001 Ford Escort sedan. The engine is a 2.0L. The transmission has been acting up lately and when the service engine light came on a mechanic friend plugged in a computer and told me there was a problem with the tcc solenoid. I took it in today for a transmission fluid change and they told me the fluid was burned. Is the burned transmission fluid something bad? If so what should be done to the transmission?
Thankyou for help
Mar 3, 2007 at 8:22 AM
CHEVY22
  • 1,375 POSTS
im sorry to say when you get a code for the tcc there is an internal problem and the fluid being burned is very bad , this means there is an internal problem soory to say its time to take it in for an overhaul
jim
Mar 3, 2007 at 8:53 AM
Suggested Repair
Have the transmission overhauled. A TCC solenoid code plus burned fluid indicates an internal transmission problem.
Conversation Summary
The owner of a 2001 Ford Escort 2.0L sedan reported transmission trouble, a service engine light, and a TCC solenoid code. After a fluid change, the fluid was found burned. The expert said burned fluid and a TCC code indicate an internal transmission problem and recommended an overhaul.
