2001 Ford Escort No-Start Coil Pack Code
CCBS5120
2001 Ford Escort ZX2, 40,000 mi.
Cranks but doesn't start, code says new coil pack, but SIX coil packs later, still won't start. Is there something "burning out" coil packs. When new one is installed, starts once, dies, never starts again and re-displays bad coil pack code. Have gotten car to run for a few months on a coil pack from old Explorer, but all new ones are useless. Must be something burning them out?
Thanks in advance. Don't want to install another one until this is solved.
Mar 2, 2007 at 1:24 AM
TAURUSWHEEL
  • 718 POSTS
I would say it's time to get it to the Ford dealer for a diagnosis, could need testing on the circuits involved and there's probably only so far you can go without specialized tools..
Mar 2, 2007 at 12:43 PM
CCBS5120
I finally got a coil pack mady by Motorcraft that works...there is apparently a problem with these as only 2 in 10 have actually been working parts.
thanks for all your time and input
Mar 6, 2007 at 1:05 AM
Suggested Repair
Install a genuine Motorcraft coil pack, since the owner found most aftermarket packs failed immediately. If the no-start and coil-pack code return, have a Ford dealer test the related circuits with the proper tools.
Conversation Summary
A 2001 Ford Escort ZX2 cranked but would not stay running and set a coil-pack code. Several new packs started the car once and then failed, while an older Explorer pack ran for months. An expert recommended dealer circuit testing. The owner later reported that a Motorcraft pack worked and that most of the other packs were defective parts.
