1994 Ford Escort Airbag Light Code 32
POLARBEAR
1994 ford escort LX .
1.9 liter. 134000 kilometers
I have the air bag light flashes a 3-2 code .It is not constant, every time the car runs .It will not flash for days at a time then it will suddenly appear flashing this code again.Some one told me it is a ground problem..Is this true if not what can I do to correct it?
Apr 8, 2007 at 4:23 AM
TAURUSWHEEL
  • 718 POSTS
If indeed it is code 32, that indicates some sort of resistance issue with the driver-side airbag, to correct it, I would recommend someone trained in airbag repair diagnose it,, airbags can be dangerous, some repair sites will not even entertain airbag questions.. it could be something relatively easy to replace once found, but if you're not familiar working with airbags, I wouldn't start pickin' and probin', might cause an explosion when you least expect it.
Apr 8, 2007 at 6:53 AM
Suggested Repair
Have a trained airbag technician diagnose code 32, which indicates a driver-side airbag resistance issue. Do not probe the airbag system yourself.
Conversation Summary
The owner of a 1994 Ford Escort LX reports an intermittent airbag light flashing a 3-2 code and wonders if it is a ground problem. The expert says code 32 points to a resistance issue with the driver-side airbag and recommends professional diagnosis rather than probing the system, which can be dangerous.
