My car turns over but wont start
SEVE12345
  • 30 POSTS
Can the relays be causing this problem?
Monday, March 10th, 2008 AT 7:44 PM
SEVE12345
  • 30 POSTS
What is the pcm relay? I dont know how to find the transaxle
Tuesday, March 11th, 2008 AT 3:46 PM
SEVE12345
  • 30 POSTS
Thanks for all the help guys I found the problem it was the ignition switch. Didnt even change the relays went to ford and they sayed change the ignition switch and I did and it started
thanks
Wednesday, March 12th, 2008 AT 9:42 PM
MASTERTECHTIM
  • 4,749 POSTS
Seve12345 you were right there 5 days ago. If you had only checked the ignition switch output on that blue wire, you would have been driving a lot sooner. Anyway good job.
Thursday, March 13th, 2008 AT 4:45 PM
RANDY ARWOOD
  • 28 POSTS
Hey I hope the guys who helped this fella are still around. I have a 94 escor with a 1.9 liter and have a crank but no start condition. I have check all the things you instructed th o.P. To check and have voltage on the blue ignition wire and my relays click and have continuity but still no spark at the coils, brand new coil by the way. I'm leaning towards the computer as the issue, how do I continue from here, please help?
Wednesday, April 10th, 2019 AT 7:12 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,513 POSTS
Can you hear the pump come on in the fuel tank for five seconds when the key is turned on without cranking the engine? Here is a guide to help you get started:
Thursday, April 11th, 2019 AT 9:36 AM
RANDY ARWOOD
  • 28 POSTS
Yes the fuel pump works just no spark.
Friday, April 12th, 2019 AT 6:56 AM
RANDY ARWOOD
  • 28 POSTS
I've done all the guides said to do, I definitely do not have spark. I have a new crank sensor but have not put it in yet. The relay is absolutely good, I pulled it out and tested continuity through it and there is a click when installed. My check engine light comes on when key is turned as well. Have to go to work now I will check in later, thanks for the help.
Friday, April 12th, 2019 AT 7:09 AM
KEN L
  • 47,513 POSTS
I would do the crankshaft sensor first. here is a video that shows a similar car getting the sensor replaced:
https://youtu.be/_xoGyRrHYbM
Friday, April 12th, 2019 AT 10:39 AM
RANDY ARWOOD
  • 28 POSTS
I've already pulled the crank sensor and ohms it out and compared it to the new one and they are the same. But I will install the new one anyway and report back.
Friday, April 12th, 2019 AT 4:53 PM
KEN L
  • 47,513 POSTS
Yep, a sensor can still be bad even though it tests good. Let me know.
Saturday, April 13th, 2019 AT 11:04 AM
RANDY ARWOOD
  • 28 POSTS
Changed it, but found the real problem. Internally broken spark wire, looked new but tested bad. Found the car has blown head gasket also though. So I will be doing a head, water pump, and timing belt. Thank you for the help.
Sunday, April 14th, 2019 AT 10:27 PM
KEN L
  • 47,513 POSTS
Good to hear, please use 2CarPros anytime we are here to help. Start a new post if you need instructions and diagrams to help you get the job done.
Tuesday, April 16th, 2019 AT 10:59 AM
