2001 Ford Crown Victoria
WEAKEYES
  • 2001 FORD CROWN VICTORIA
  • V8
  • 97,000 MILES
The engine will not start after a short drive after being parked while shopping. After a period of time 30 to 60 minutes the car will start an runs as normal, It has the symptoms of no fuel. I have replace the fuel filter after the second problem but then it occurred the third time
Tuesday, November 24th, 2009 AT 4:47 AM
BMRFIXIT
  • 19,053 POSTS
Check what is missing
suspect and check relays
Tuesday, November 24th, 2009 AT 6:01 AM
WEAKEYES
If I understand your reply to my original question was check the relays. The only relay I am aware of is the relay for the fuel pump that has a reset in the trunk. How would that relay be intermittent?
Tuesday, November 24th, 2009 AT 9:31 AM
BMRFIXIT
  • 19,053 POSTS
The relay box under hood
what you have in the trunk is the Intertia switch this is ON or OFF
when it fail to start open hood and check for spark, check for fuel
Tuesday, November 24th, 2009 AT 4:39 PM
WEAKEYES
Your answer does not make any sense. Switch in truck will not reset itself. Fuel is adequate showing 3/4 full and there is spark.
Wednesday, December 23rd, 2009 AT 7:19 AM
BMRFIXIT
  • 19,053 POSTS
Sorry that I am not making sense
Inertia switch is in the trunk
relays under the hood
I dont know how that doesn't make sense to you
Sorry I was unable to help
Wednesday, December 23rd, 2009 AT 9:06 PM
