Hello !
Check the starter.
Could be faulty also the "signal" wire that feeds the starter could be disconnected or broken if possible check the signal with a light tester if good then
check the battery cable that goes directly to the starter be sure that is making a clean solid contact on both ends (battery and starter)
if everything checks good then the starter is faulty, remove it and bench test it.
Something else !
Be sure that the shifter its on parking!
(Neutral safety switch could be faulty or not closing the contact )
Move it a little bit and try to start the engine.
Good luck and let us know on your findings!
SPONSORED LINKS
Thursday, January 3rd, 2008 AT 7:58 PM
