1986 Crown vic. Quit running and will not start
BIG BEAR DRIVER
  • 1986 FORD CROWN VICTORIA
I have a 1986 crown vic. 5.0 liter, 136,000 mi. Driving home from work 14 mi. Trip Temp. Was 38. Out side. Car has been ruining great, plugs, wires, cap& rotor, full filter are eight mo. Old. A half mi. From home, the car just quit ruining, pulled over and the car re-started, pulling into my drive the car quit again. I checked all the wire connections, nothing was lose. The car started back up and went ten feet and died again, and now it will not start. I checked the full filter, its not clogged, plenty of fuel coming out of the fuel pump. I ran the car low on gas twice, it now has 1/8 th of a tank full. The car turns over great, and has been ruining great up till now. When the car quit, it was like turning off the ignition switch. Any ideas? Thanks for any help you can give me, chuck.
Wednesday, November 28th, 2007 AT 1:14 PM
BLACKOP555
  • 10,371 POSTS
Are you getting spark? And does car fire up with starter fluid. Please post back asap
Wednesday, November 28th, 2007 AT 6:42 PM
BIG BEAR DRIVER
To answer your question, no, I was not getting a spark. I changed out the coil, and that did not help. A friend suggested I change out the ignition module, thats on the side of the distributor, and thats what the problem was. The car starts and runs great again. Thank you guys very much, and I hope this helps other crown vic. Owners, chuck.
Thursday, November 29th, 2007 AT 8:24 AM
