1986 Ford Crown Victoria no start
SFAS
  • 1986 FORD CROWN VICTORIA
  • V8
  • 88,000 MILES
Have this car stored indoors for over 10 years. Ran when parked. Put in new battery, vehicle cranks, when turning key can hear multiple relays under hood engaging. Fuel gauge now not working, but put in 5 gallons of fresh fuel. Not sure but dont remember if I should hear fuelpump hum, but I do not. Relay in the trunk is working.
Saturday, March 28th, 2009 AT 7:56 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, March 29th, 2009 AT 6:31 AM
SFAS
I have spark. No apparent ignition problems. I dont remember if on this car if I should hear a hum from the fuel pump. If so, I dont. How do I check. WHERE IS THE RELAY. THANK FOR YOUR HELP
Monday, March 30th, 2009 AT 8:59 AM
The fuel pump relay is in the engine bay on left inner fender panel
https://www.2carpros.com/forum/automotive_pictures/12900_fp_relay_8.jpg
Monday, March 30th, 2009 AT 1:17 PM
SFAS
Still no start. No fuel at rail up at injectors. Will sputter with starting fliud. No hum from pump in rear. Switch in trunk has no power on either leads. Can I overide and hook some kind of temp fuel tank to go directly into the fuel rail in the engine bay.
Saturday, April 4th, 2009 AT 11:57 PM
Did you test the fuel pump relay? Try powering the fuel pump direct from the battery and see if it comes on.
Sunday, April 5th, 2009 AT 5:16 PM
