1997 Ford Crown Victoria No Start Click
FEEVABOY
I have a 1997 Ford Crown Victoria with 154,000 miles and when I try to crank up the car all I hear is a click sound, Also if I try to crank up the car with the headlights on they go about half way deam. I just brought the battery about 6 months ago and I don't know whats the problem could it be the alternator or the starter or (someone told me) it could be the battery relay?
Feb 19, 2007 at 10:12 AM
CHEVY22
  • 1,375 POSTS
the battery is dead , it would need to be charged on a charger and checked , once its checked , then you can check other charging system components , but the battery needs to be at 12 volts first, so start there , checking the battery after a jumpstart does not count as charging ,
thanks
Feb 19, 2007 at 10:15 AM
Suggested Repair
Fully charge the battery on a charger and test it; it should be at about 12 volts before checking the charging system, starter, or relay. A check after a jump start does not count as a proper charge.
Conversation Summary
The owner of a 1997 Ford Crown Victoria with 154,000 miles hears only a click when trying to start, and the headlights dim about halfway. The battery was replaced about six months earlier, and the owner asked whether the alternator, starter, or battery relay could be at fault. The expert said the battery is discharged and must be charged and checked to 12 volts before other charging-system components are tested.
