1996 Ford Crown Victoria No Start
GREENEYEDT32
1996 Crown Victoria Police Interseptor,4.6 L
When i turn the key to start it wont start, if i get a jump start it fires right up. We put a starter switch on from the starter staight to the battery, that worked once and now my car wont start with the switch or by getting a jump start?
Feb 27, 2007 at 12:28 AM
2CARPRO JACK
  • 11,533 POSTS
Does the car have an aftermarket alarm? if it does remove it and try again.Otherwise get a test light and see if the small wire at the starter lights up when someone cranks it.
Feb 27, 2007 at 11:56 PM
Suggested Repair
If an aftermarket alarm is installed, remove it and try starting again. Otherwise, use a test light to check whether the small wire at the starter lights when the key is turned to crank.
Conversation Summary
A 1996 Ford Crown Victoria Police Interceptor with a 4.6L engine will not start with the key. A jump start initially worked, and a temporary switch from the starter to the battery worked once, but neither method starts it now. The expert advises removing any aftermarket alarm and testing the small starter wire for power while cranking.
