1988 Ford Bronco Rusted Hitch Ball
AMATEUR
This isn't specific to Ford, but I have a 1988 Full Size Bronco with a step bumber trailer ball. I'm trying to install a frame-attached receiver hitch and can't get the rusted ball off of the bumper. I have tried two pipe wrenches and a sledge hammer, but there is no moving the nut on the bolt. I'm beginning to think I'll have to hack saw and drill it to pieces, but I thought I would ask for some ideas first. By the way, the bolt is in the way and I can't install the new hitch until it is removed. Thanks.
Jun 2, 2007 at 8:38 AM
98RANGERXLT
  • 301 POSTS
Try spraying it with pb blaster or wd40.
Jun 2, 2007 at 9:42 AM
AMATEUR
Thanks for the suggestion. I tried lubricating it. I think that nearly 20 years was just too much. At any rate I just got out the drill and made mincemeat of it. Job done.
Jun 4, 2007 at 2:55 PM
Suggested Repair
Soak the seized trailer-ball nut with a penetrating oil such as PB Blaster or WD-40 and try to break it free. If the rusted fastener still will not turn and blocks the new hitch, cut or drill the bolt out so the frame-mounted receiver can be installed.
Conversation Summary
The owner of a 1988 Ford Bronco could not remove a rusted step-bumper trailer ball that blocked installation of a frame-mounted receiver hitch. Pipe wrenches and a sledgehammer did not move the nut. An expert suggested spraying it with PB Blaster or WD-40. After lubrication failed, the owner drilled the fastener apart and completed the job.
