1988 Ford Bronco II Starter Cable Overheats
HARDHEAD FORDMAN
I have a 1988 Ford Bronco 2 with over 150000 miles on it & it's an automatic trans, not a four weel drive .2.9 liter fuel injection .but only have a few problems with . For one 4 weeks agp the starter went out and I replaced it only to have it turn over a few times and quit all together so I replaced the relay but the original one was a three prong & the one I got is a 4
prong but the clerk @ advance said just use three and not the( I) prong so I did . My 4 weeks have been trouble now the starter cable is overheating at the relay and it still will not turn over and run right any help would be great my wife wants her chevy back and I want to give it to her thanks up front HardHeaded Ford Man
Jul 8, 2007 at 12:33 PM
MERLIN2021
  • 17,250 POSTS
If the cable is getting hot, you have too much resistance in the circuit. Check for corrosion in battery cables.
Jul 9, 2007 at 2:01 AM
HARDHEAD FORDMAN
[quote:f9a2ba4067="merlin2021"]If the cable is getting hot, you have too much resistance in the circuit. Check for corrosion in battery cables.[/quote:f9a2ba4067]
I forgot to put in here and I'm sorry but I replaced them as well , I do thank you for your input though could it be I just got the wrong relay ? does it have to be a manufactored part for fords or can you use univerciil part like that because this is a big bummer I'm going to see if I cann't get it running tomorrow long enough to put a reader on it .if you think of anything else please let me know. Thanks again .
Jul 13, 2007 at 1:49 PM
Suggested Repair
A hot starter cable indicates too much resistance in the circuit. Inspect the battery cables and connections for corrosion or poor contact, even if the cables were recently replaced.
Conversation Summary
The owner of a 1988 Ford Bronco II with a 2.9L fuel-injected engine and automatic transmission replaced the starter and then the starter relay after it stopped cranking. The replacement relay has four terminals instead of three, and the starter cable now overheats at the relay while the vehicle still will not crank. The expert said cable heat means excessive circuit resistance and advised checking the battery cables for corrosion. The owner replied that the cables had already been replaced and asked whether the incorrect relay could be the cause, but no further expert reply was given.
