1996 Ford Bronco Hard Restart Sputter
RISTONE7
1996 Bronco, Eddie Bauer, 5.8 engine, auto transmission 134000 miles. Just recently I have started having problems. When I furst start up, it starts and runs fine, but after I drive to wherever, and turn off the engine, when I attempt to restart, the engine coughs and sputters, trying to stall out. Once recently, it wouldn't even start at all for a very long time and several attempts. When finally restarted, the engine misses and sputters for a period of time, then seems to clear itself and run smoothly. Can you give me any idea of what is going on, and how to cure it?
Jul 11, 2007 at 4:42 AM
INDYUKE
  • 416 POSTS
Does the check engine light come on at any time?
Jul 11, 2007 at 2:57 PM
RISTONE7
Yes, the engine light was blinking then steady. But then after a couple of restarts it goes out.
Jul 12, 2007 at 4:51 AM
INDYUKE
  • 416 POSTS
When the check engine light comes on, it means that there is a fault and the PCM has stored a code (or several).
If you are able to aquire a scantool to retrieve those codes, then those codes would be the clues we need to diagnose the problem. Let us know.
Jul 12, 2007 at 12:57 PM
Suggested Repair
When the check engine light is on, retrieve the stored PCM trouble codes with a scan tool and use those codes to diagnose the hard-restart and sputtering problem.
Conversation Summary
A 1996 Ford Bronco 5.8 starts and runs fine when cold, but after being driven and shut off it coughs, sputters, and sometimes will not restart for a long time. Once restarted it misses briefly, then clears and runs smoothly. The check engine light blinks, then stays on, and later goes out after a few restarts. The expert explained that the light means the PCM has stored one or more fault codes and advised retrieving those codes with a scan tool before further diagnosis.
