1989 Dodge Truck starting
MIKEJONES423
  • 1989 DODGE TRUCK
Engine Mechanical problem
1989 Dodge Truck V8 Two Wheel Drive Automatic
i have a dodge d150 sometimes it starts sometimes it doesnt replaced the fuel filtrer but didnt fix it. I thought it might be the fuel pump but when it doesnt start if you keep trying to crank it again on and off it will start eventually so what might this problem be
Saturday, November 1st, 2008 AT 12:20 AM
BLACKOP555
  • 10,371 POSTS
Next time it wont start dump some gas or spray some starting fluid down the throttle body and try to start it. Does it fire right up then? If so I would be suspecting a fuel system issue, if not start checking for spark on all cylinders.
Temperature matter?
Saturday, November 1st, 2008 AT 9:04 AM
