2000 Dodge Stratus lopes & keep killing!!!
2000 DODGE STRATUS
SUPERDNO38
i have a 2000 dodge stratus 132,000 m. 2.4 DHOC. my car kills when i come to a stop or when i make a sharp turn after slowing down. i can start it in about 60 sec. it has a lope at idle,but good power . sometimes after a hard running it kills while idle and park. these are some of the things that was done.(replace sparkplug & wires, coilpack, airfilter,MAP sensor,brakes & rotors brake switch,chrysler/dodge service dinostic test.the code that came up was map sensor &brake switch which i change, they also check the fuel for pressure,the cylinder compression & the computer) i don't know what else to do .CAN ANY ONE HELP ME PLEASE !!! :cry:
I tried cleaning the throddle plate but this did not work. Should I change the Idle Speed Control Motor?
Aug 5, 2007 at 4:34 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a slow Idle Speed Control Motor.If they dont react quick enough the engine can die, but will restart.Also try cleaning out around the throttle plates with a little carb spray and a rag
Aug 6, 2007 at 1:01 AM
