1996 Dodge Stratus died and wont start
DONETTASB
  • 1996 DODGE STRATUS
I have a 1996 Dodge stratus 2.4 ltr. The tachometer quick a few weeks ago. Then I was driving today and going up a small incline. I tried to accelerate, but only made up to about10-15 mph. Almost at the top of the hill it slowed and died. It did not sputter and seemed fine before I started up very small incline. I was low on gas and added some thinking I had just ran out. It will turn over, but will not start. Checked fuses and added more gas. Nothing. We had the fuel filter changed less than 6 months ago. Have had a lot of black deposits on pipe of muffler. Have about 93,000 miles and have had egr replaced 20000 miles ago along with cataletic converter. Please help. Thanks Donetta
Tuesday, November 27th, 2007 AT 12:57 AM
Check engine light is it On or has flashed?
Last major tuneup?
Have had a lot of black deposits on pipe of muffler. Have about 93,000 miles and have had egr replaced 20000 miles ago along with cataletic converter. Is this mixed with black smoke?
Get the oxygen sensor/s and Cat recheck
It will turn over, but will not start. Check for fuel and spark and comeback and tell me what's missing, this one can be a bear to find.
Is this a DIY project if so bear in mind it requires special tools and testing equipment-Don't have it take her in.
Tuesday, November 27th, 2007 AT 1:09 AM
DONETTASB
  • 5 POSTS
It has fire and fuel. Took off the breather and squirted starter fluid into it, started but then dies again.
Tuesday, November 27th, 2007 AT 9:05 PM
Get deep in the fuel system-check fuel pressure and comeback with readings
Tuesday, November 27th, 2007 AT 10:02 PM
DONETTASB
  • 5 POSTS
I finally got it running. Fuel pump had bad wire. Now I need one more thing. The horn has started honking and won't quit. Took out fuse. Relay has been replaced. Can not get the dang cover off. Unplugged battery overnight undid screws. Can't get front of it off. Any thing else to loosen?
Thanks Donetta
OOPS 1996 Dodge Stratus 2.4 -4cyl
Sunday, December 9th, 2007 AT 10:52 PM
