1996 Dodge Stratus Stratus cranks but does not start
CASTAED
MEMBER
1996 DODGE STRATUS
4 CYL
FWD
AUTOMATIC
174,000 MILES
Hello. I have a 1996 stratus that is cranking but won't start. It slowly started intermittenly and has now taken over. I had these issues about 5 months back and it turned out to be a bad crankshaft position sensor. The car is acting the same way again and I think it is the same sensor. Is this a common issue with this car? Any help is much appreciated. Thank you
SPONSORED LINKS
Thursday, October 23rd, 2008 AT 11:10 AM
MECHANIC
HI castaed and welcome to 2carpros
Disconnect a sparkplug wire or 2 ground it and have helper crank engine over-do you have a snapping blue spark-if not check the CPS again
Thursday, October 23rd, 2008 AT 11:35 AM
CASTAED
MEMBER
I checked the spark and it was fine. So I replaced the CPS. It turns on but when it wants to. Although I noticed when the car is cranking it is alos shaking. Maybe like a cylinder is off or it's not getting gas. I can hear the pump turn on. I also did the fule pressure release up front by the A/C lines and it spit out fuel. I'm at a loss.
SPONSORED LINKS
Friday, October 24th, 2008 AT 6:33 PM
MECHANIC
Check the fuel pressure with a fuel pressure gauge this is the only way to tell if its producing the correct fuel pressure-
