1996 Dodge Stratus Will not start
48,000 MILES • 4 CYL • FWD • AUTOMATIC
GEORGEINGLE
We are tring to start the car and the lights come on but the starter will not turn. It is not making any noise.
Nov 3, 2010 at 11:39 PM
JDL
  • 16,098 POSTS
You need to make sure the battery has a full charge. Use a voltage tester across battery posts, everything turned off. The generic spec for a full charge is around 12.6 voltage. Check that all battery connections coming and going are clean and tight on all ends.
Nov 4, 2010 at 2:38 AM
