MAF or intake vaccum leak?
CHRYSLER
PITCHERFAN19
my car died on me last week and the dealer said it needed a tune up. they replaced plugs,ignition wires, distributor cap,rotor, and replaced bad intake gaskets(upper and lower). 30 miles later my car has similar sypmtoms but not as severe. it idles rough around 500 rpm and doesn't quite have the power it should, it seems sluggish. the service engine light is on and shows P0174, lean in bank 2. my mechanic diagnosed a bad MAF or an intake vaccum leak(possibly bad gaskets?). he was not defintive though. it seems strange but the car runs normal when the cooling fans turn on or the MAF is unplugged. the answer seems simple(change the MAF), but i just want another thought.
Feb 10, 2006 at 12:38 PM
PEPPERMRJ
  • 1,158 POSTS
A make, model, year, and mileage are a definite help.
Being that the intake manifold gaskets were just replaced I would recommend the following.
In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
Inspect all vacuum and PCV hoses, replace if necessary
Check for a dirty fuel filter and proper fuel pressure
Good luck and let us know.
Feb 12, 2006 at 3:16 AM
PITCHERFAN19
sorry about that. its an 02 dodge stratus r/t, 5 speed, 58k miles. the fuel pressure is good, the injectors are good, the filter is in the tank. thanks for the advice, i'll let you know!!
Feb 12, 2006 at 3:55 AM
PITCHERFAN19
codes today were P0174(lean bank 2) and a new code of P0171(lean bank 1).ok so i replaced the MAF sensor and cleared the codes. about 15 miles later the service engine soon light pops back on. i assume the same 2 codes. the engine still idles very rough. it's like it wants to die around 500 rpms and then catches itself and shoots the rpms back up. now im resorting to using fuel additives(heet) in case maybe the gas is bad, and it has been suggested to me to use an oil additive/detergent(CD2). i doubt this will really help but it can't hurt. BTW, this is a 3.0 V6 Mitsubishi engine, a real pain in the butt to diagnose from what i am told.
Feb 15, 2006 at 9:48 AM
PEPPERMRJ
  • 1,158 POSTS
Double check the MAF installation and connections.
Lean means that unmeterd air is getting into the system. Check all your vacuum lines, especially the PVC and brake booster lines.
It is possible to still have a bad MAF or an intake leak around the manifold.
Take a look around and see if some other wires or hoses have come off or rubbed thru. With all the work that's been done underneath the hood it is worht checking.
Feb 15, 2006 at 9:59 AM
PITCHERFAN19
so the codes are the same, but i found it odd that they both were thrown twice in 24 hours. P0174,171,171,174(in that order). is that normal? also im still confused as to why the cooling fans starting immediately smooth the idle out.
Feb 16, 2006 at 12:33 PM
Suggested Repair
Recheck the MAF installation and connections, then inspect all vacuum lines, especially the PCV and brake booster hoses. Also look for an intake manifold leak and any hoses or wires disturbed during the recent under-hood work, since the lean codes indicate unmetered air.
Conversation Summary
A 2002 Dodge Stratus R/T with a 3.0 V6 developed a rough idle near 500 rpm and lean codes P0171 and P0174 after a tune-up and intake gasket replacement. The idle smoothed when the cooling fans ran or the MAF was unplugged. Fuel pressure and injectors were reported good, and replacing the MAF did not fix it. The expert advised checking MAF connections, vacuum and PCV lines, the brake booster hose, and possible intake leaks or disturbed hoses and wiring.
