When the pump tries tp reprime, there is air that must be forced out through the injectors, the system is sealed so it takes a couple times of the injectors hitting for the air to get out. Hot to cold, the PCm uses different parameters to start in differnet conditions, cold requires more fuel, hot less fuel. If the system is bleeding down it will be difficult to fix other problems, especially if an injector is questionable
Saturday, January 11th, 2020 AT 2:24 PM
(Merged)
