2002 Dodge Ram will not fire
VERMINATOR
Engine Mechanical problem
2002 Dodge Ram V8 Four Wheel Drive
I have a 4.7 magnum in my ram 1500 the plugs don't seem to be firing. what is the most likely part to start with. I have already replaced the plugs.
May 21, 2009 at 4:08 AM
JDL
  • 16,098 POSTS
Hello, checking your trouble codes may lead you in the correct direction?
With the engine cranking, check for primary voltage at the coil and injectors, usually a dark green wire with orange stripe. If there is no voltage, that comes from the asd relay, I'm not saying the relay is faulty. A common reason the computer won't ground the relay is because the computer doesn't see the cam and or crank sensor signal. I can't tell you what to replace, I can only suggest what to check, the rest is up to you.
May 21, 2009 at 4:44 AM
