2002 Dodge Ram Starting and changing thermosat
RONALD54
  • 2002 DODGE RAM
  • V8
  • 134,000 MILES
Truck will not start, battery low and how do you change thermostat!
Monday, February 1st, 2010 AT 7:52 PM
  • 109,799 POSTS
Have you tried recharging the battery?
As far as the thermostat, follow the upper radiator hose to the engine. It will end at the t-stat housing. Drain the coolant from the radiator to a level lower than the t-stat. Remove the upper hose, unbolt the housing and replace the t-stat. Reverse order to replace.
Tuesday, February 2nd, 2010 AT 8:12 AM
