2002 Dodge Ram Died jus like that
KRISL
  • 2002 DODGE RAM
  • V8
  • 4WD
  • 97,000 MILES
I was driving the truck with no problems at all. Suddenly when I try to start it next morning it won't start. I can hear the fuel pump working, check my battery. Engine rotates but won't start(rotates slowly). What can be the problem? No spark plug? Or something is wrong with the engine that is rotating slowly?
Sunday, October 25th, 2009 AT 10:17 AM
  • 109,874 POSTS
Since the engine is turning slowly, I need you to remove the battery, fully charge it, and have it load tested at a local parts store.
Let me know what you find so we can move to the next step.
Monday, October 26th, 2009 AT 10:38 AM
KRISL
  • 5 POSTS
I have warranty on my battery from Walmart. I went there they have test it and told me that the battery is good.
Maybe I should go to Autozone or something like that?
Monday, October 26th, 2009 AT 11:06 AM
  • 109,874 POSTS
If the battery is good, then you need to make sure the battery terminals are clean and tight, and the ground to the engine block is clean and tight. I would recommend if they are, take the truck to auto zone and have them check the draw from the starter. It may be bad.
Let me know what you find.
Monday, October 26th, 2009 AT 11:56 AM
KRISL
  • 5 POSTS
I can't take it to autozone because the truck won't start. Can I just pull out the starter and take it to them? Is the solenoid coming out together with starter?
Thanks for your help
Monday, October 26th, 2009 AT 12:11 PM
  • 109,874 POSTS
Yes, you can take the starter. Make sure to disconnect the battery before working on it. They can bench test it for you and determine if it is drawing too many amps. Also, make sure all wiring looks good. If it was drawing too many amps, it could have overheated the wiring.
Monday, October 26th, 2009 AT 12:52 PM
KRISL
  • 5 POSTS
Okay. Is it hard to remove the starter? Which store is better? AutoZOne or O'Reilly auto parts? I will try to do it tonight. Is there any other part that can cause the engine to rotate slowly?
Monday, October 26th, 2009 AT 1:24 PM
  • 109,874 POSTS
The only thing I can say would be a bad connection between the battery and the starter, a bad cable, corroded bround or battery terminals. As far as a slow cranking, it could be any of the items I listed.
Monday, October 26th, 2009 AT 1:41 PM
KRISL
  • 5 POSTS
I found the problem! Spark plug wire come off by distributor. How that happened? A week ago my car was in auto shop, did they loose to make sure I'll be back?
Thanks For Your Help I really apreciate it.
Monday, October 26th, 2009 AT 2:15 PM
  • 109,874 POSTS
Wow! That was a cheap easy fix. I'm glad that is all it was. However, I'm confused how it caused the engine to crank slowly. Regardless, I'm glad it's fixed.
Let us know if you have questions in the future and thanks for using 2carpros. Com
Monday, October 26th, 2009 AT 9:14 PM
