My truck did not pass inspection. The Computer showed a fualt in the temp sensor (ECT), I put in a new sensor and now the truck will start when cold and run fine, but when engine gets hot and you shut it off it will not start. When I do get it started after several tries it is loaded up with gas and runs rough. The computer now is showing a code that the computer is reading that the truck is trying to start at -40 when hot. Can you tell me what the problem is? Jeff
Apr 1, 2009 at 3:27 AM
